Single post categories and single post tags on same line for a new post
Hi guys.
I’m working hard to build my future blog/news magazine/press media. I use the newspaper magazine pro template, but I modified it a lot with parts from a few other templates. I’m trying to create something new but I can’t do what I want.That’s why I need your help.
In my actual website, I use the categories for the first level of information structure (categories are the elements of my submenus. But I will use the tags, in a second level, to be more specific on my posts. I would like to show, for each future post, the category (only one by post) and the tags (maximum 5 by post). When I’ll post, I hope the readers will see for each post the category and beside it the tags. All on the same line, not on two lines. I tried and tried, but I’m sad that I’m not able to get th solution.
Please help me….. with an easy solution and without any coding (I’m not technical at all).
Thank you so much for your time and kindness. I’m crossing my fingers…
Jean
Hello Jean,
You can add a row and set the layout like this https://i.imgur.com/TKjQrv0.png and make them inline https://i.imgur.com/j2if8ZP.jpeg
Hello Anamaria,
Thank you for your tips. I’ll try this and give you feedback about this. I hope that will be the solution that I’m looking for!
Have a nice day!
Hello Anamaria.
I tried what you suggested me but nothing works. I just took a screenshot to send it to you but I don’t know how to transfer this image to you. I also put some text on it for understanding easily.
Thank!
Hello Anamaria.
I’ve got a second but different big problem. A Tagdiv error message appears in red.
I always get an error when I save my work. The error is for the header and the footer. But for the content everything is OK.
“Invalid data Current state has involved an issue. You could try an UNDO operation (CTRL+Z/CTRL+SHIFT+Z)”
Thank you for your solution about this important issue and about the first topic (category and tags on the same line).
Jean
We would also like to take a look, so please email us at contact@tagdiv.com and provide the wp-admin and cPanel access. Include the link to the topic in the email.
