【HELP】Article's load more botton doesn't work
I don’t know if I can explain the problem correctly, cuz I’m japanese.
Please look at my site for now.
https://takehero.com/
load more botton is displayed 他の記事を読む.
and click Article’s load more botton, it would not work.
But when I click it on customize mode, it work.
WHY?
I tried to do something I can. but I Couldn’t.
so please teach me.
sorry for my poor english.
  • This topic was modified 7 years by take.
I have checked your website and it seems that problem happens due to your Autoptimize plugin, as you can see here -> https://www.screencast.com/t/x9qAjZJsDmo Please check the configuration of this plugin because not all of the options from there are working properly, sorry!
Thank you catalin!
Finally, I solved it by your advice that just removing this check
->https://www.screencast.com/t/h350dEUHY
Thank you so much!
