포스트 글자 설정(THEME Fonts 설정)
hello
This is a post text setting setting question.
From Theme Fonts
How do I set up post headings, post font size fonts, etc.?
I can fix it using the Gudenberg block plugin or using yellowpencil, but it crashes with Newspaper.
So, I’m going to set it up in Theme Fonts.
Where can I set what
– Noto sans kr font, text content size 18, alignment hamburger, height 2.0
– I want to set H1 24 px, H2 22 px, H3 20 px, H4 18 px, etc.
Second, in Theme Fonts, please tell us the function description and operation method in each menu of the subcategory https://ibb.co/6yZWpLY menus.
Next question.
Post → Block → Advanced → Additional CSS Classes
tell me how to use
https://ibb.co/XF0hyB7 using blocks often
After creating a reusable block, an error occurs when loading it in a new article. please test this
If you are using cloud templates, then you can set all the settings on that cloud template using tagDiv Composer – https://i.imgur.com/2d6Cuk2.png – https://i.imgur.com/7ThBalt.png (the theme panel fonts will apply only for standard template from tagDiv Standard Pack plugin and some options that are general).
“Second, in Theme Fonts, please tell us the function description and operation method in each menu of the subcategory https://ibb.co/6yZWpLY menus.” those will be applied only for standard templates added by this plugin – https://i.imgur.com/UbeyHn1.png – https://i.imgur.com/n6oXkyR.png
“Next question.
tell me how to use”
You need to set the class on that element, save/update/publish the post and use that class to create your custom css -https://forum.tagdiv.com/create-custom-code-using-the-browsers-inspector/
Thank you Carlin for your reply, but I’m having a hard time understanding what you’re saying.
Are you saying it can be specified in both the TagDiv Composer and the theme panel?
In TagDiv Composer, when changing letters, all selections are made, so aren’t all of them applied the same? So, shouldn’t we specify each in the theme panel?
The third is “Post → Block → Advanced → Additional CSS Classes
Tell me how to use” please tell me more precisely
It’s hard to understand in writing
I will try to explain it more clearly.
The theme uses the tagDiv Standard Pack plugin that brings options in the theme panel for the standard templates (old, they cannot be edited in the frontend, only using the on/off options in the theme panel).
As I said, if you use a standard template, then the elements can be edited from the theme panel, and if cloud templates are used, then they can be edited on the frontend with tagDiv Composer.
“The third is “Post → Block → Advanced → Additional CSS Classes
Tell me how to use” Please tell me more precisely
It’s hard to understand in writing”
Please try this guide – https://wordpress.com/support/wordpress-editor/adding-additional-css-classes-to-blocks/
