#28014 How to modify predefined grid element?
hello,l use visual composer would like to create my home page.
Then I select the grid 2 element,but the photo not at center.
how can I modify it?
question 1
and I use the block 2 element,but it will show all the content of article.
how can I let it only show the top two lines?
question 2
I try to fine the solution on visual composer website.
in this article ,it say “Select grid element you want to modify under Grid param window tab “Item design”.”
https://wpbakery.atlassian.net/wiki/pages/viewpage.action?pageId=3604489
where can I find the “Grid param window”?
These elements are not visual composer elements but theme specific ones.
The first issue with the images is a simple one. You need to use images that are bigger than the container. Check your image sizes and the containewr size. The theme does not strewtch images, it only crops them. If your image is smaller than the container, then you need to upload a bigger one for it to display properly. Please follow this guide: https://forum.tagdiv.com/thumbnails-fix-strange-looking-images-on-blocks/
For the second issue with the excerpts, please filter your excerpts by letters here: http://screencast.com/t/zZhUXQPR because your language does not use spacing between words. If this is the case, the theme will think all of the post content is just one big word.
