A few problems
1. My favicon has uploaded but does not appear
2. I would like a bigger option for a logo (which takes over the entire ad space on the right side)
3. I installed the Demo and I then set up my custom homepage to look like the demo but when I enter my websites name .com, I only see the demo and not my posts and all other featured why?
4. I just uploaded the theme do I have to manually upload any updates on filezilla? Where do I see the updates?
5. I uninstalled the entire theme and am totally confused as to how to get the theme looking like I want…
I am frustrated since I spent two hours getting the theme to look how I want and then in the end I had two different layouts, how I made it and the demo…
I really need some help with this since I read all the instructions and followed them, I am not sure why this is happening at all
If I can’t resolve this within the next 12 hours. I will require a full refund since my site is down and I need it up ASAP.
update:
*resolved the homepage issues… (skipped a step) woohoo :)))
New request:
1. drop down menu on the top header menu would really really helpful
I’ll be adding more of my issues as I encounter them here
I keep getting update notices for no reason
How do I set up the “don’t miss” section, with the multiple categories on the demo site?
Is that the revolution slider?
  • This reply was modified 12 years by Marija1m1.
The social counter is not showing my youtube, twitter and instagram counts
not sure why
Fixed the social counter problem
fixed
home page issues resolved
SUMMARY
Things which I still need help with
1. I just uploaded the theme, do I have to manually upload any updates on filezilla? Where do I see the updates?
2. How do I set up the “Don’t Miss” section, with the multiple categories on the demo site?
3. drop down menu on the top header menu would really really helpful
4. I keep getting update notices but nothing needs to be updated
5. Can I not use the contact me app? I already am using Jetpacks feedback option?
1. All the updates will be via FTP, replacing all files.
2. Edit you DON’T MISS block (block2) and add here for multiple categories: http://screencast.com/t/lA4YSXv2ay1
3. Unfortunately the theme was not made from the start to support drop down for top menu.
4. There is a small bug, still searching for that bug
5. What contact me app?
Thanks for the reponse, love this theme and how many possibilities it offers.
Sorry I meant the contact 7 plugin in I removed it and everything is alright.
The problem with block2 is that I do not get those clickable categories on top as in the demo?
I obviously did something wrong
Got it to work
I followed these instructions but I had to make a new category and place all the categories which I wanted to featured under that new category for it to work.
I do not know why it didn’t work when I just placed the category ID number in the place where you told me to?
1. We use Block 2 http://screencast.com/t/ihp1OsNZB1ek with follow options http://screencast.com/t/RNQSS7c7uPgI , http://screencast.com/t/YKZ83xD5YFN ,
http://screencast.com/t/jnnQrSpKwmO and the template of page must be Homepage-with article list http://screencast.com/t/XLtMmgkKGw.
Do you want to display subcategories like here: http://screencast.com/t/NOzqGU6ame
Select a category at “category filter” that have subcategories. http://screencast.com/t/y9YmZnhGP74w
No I don’t want to select subcategories, but I in the end had to to make a brand new category and place all my categories as subcategories, in order for them to appear in the block2 tabs.
Besides that I have a new problem with google.
When google was crawling my site it keeps showing me that
Google detected a significant increase in the number of URLs we could not access.
Since I changed the theme I got over 400 Crawl Errors.
I spoke to my hosting and everything is fine with them?
Is there something that I have had to do so that google can crawl the new layout?
Can you give me a list of urls that don’t work? IN google webmaster tools you should have that.
Reply via email!
Google webmaster showing an error – “Soft 404”
URL – https://beingtop10.com/wp-content/themes/Newspaper
How to fix it?
Try the solution mentioned by Chris in this topic
https://forum.tagdiv.com/topic/soft-404-url-error-detected-by-google-crawl/
Viewing 20 posts - 1 through 20 (of 20 total)
