1: ) Mobile Themes Can we show the sidemenu?
2: ) In the desktop view, I post a custom content in a special function.php file after the article. What should I do in order to display the same content in the mobile theme after the article?
Another question.
A new feature has been added with the latest updates. 3 e-mail service side menu add-on.
These services are paid.
I would like to ask you to support the newsletter for free and 300 thousand users.
Another question đ
There is no default category in the mobile theme that is featured in the category. However, you understand that you have. Within the mobile theme the featured pages on the home page do not appear.
Hi pesimist57,
1)Unfortunately, I do not exaclty understand what do you mean though side menu on mobile theme. This plugin only displays the hamburger menu, like this -> specific on mobile devices. -> https://www.screencast.com/t/aatmcVaV
2)If you want to display some custom section when you are using the Mobile theme, notice that you need to edit the theme core files, where the Mobile Theme is created and change the main functionality.
3)Regarding on Newsletter, please notice that we have our own built-in functionality regarding this and also, we do not recommend using another untested plugin for this. Please check here -> https://forum.tagdiv.com/the-newsletter-plugin/
4)If you want to change the category in Mobile Theme, you need to edit the code where this functionality is created and change it with your desired category. If you want to make this change, please send us an email at contact@tagdiv.com so I can point you in the right direction where exaclty you can make this modification through the code.
Thank you for the answers. But none of them is the solution.
