A little help with posts area please
I have installed the fastnews theme on 2 domains but both have different ‘add new post’ areas, as you can see from these google drive links:
This is the new one that I DO NOT like:
https://drive.google.com/file/d/1V2GkhpCX10Usb-rzNONuSzADYK7n-LOy/view?usp=sharing
This is the other site post area that I want to use on both sites:
https://drive.google.com/file/d/1kiIFrW12mOkQfn9aGt5cPJSbVrXlT5UP/view?usp=sharing
How do I change the first one to be like the second posts area shown from the last link above?
That would be the relatively new wordpress Gutenberg editor, introduced officially in the WordPress 5 update
– https://wordpress.org/support/wordpress-version/version-5-0/
– https://developer.wordpress.org/block-editor/contributors/faq/
If you do not want to use, wordpress provides a classic editor plugin that will disable it
– https://wordpress.org/plugins/classic-editor/
Once you install it Gutenberg will be disabled and replaced by the classic editor, the plugin also provides a few options here
– http://prntscr.com/olby4j
