So i have installed the new version of your theme and .. i start to make some changes… everyithing works perfect but when i try to change alt for images it doesn’t display on frontend
I go in Media – and select each image and complete the forumlar for alt tag
I reselect the images in the container ( Themes -> newspaper -> logo retina / logo ###### Page edit background reselect image )
And don’t appear on frontend… can you check on my website http://eurobg.eu
I make some test on my install and for my the alt text is working -> https://www.screencast.com/t/Umx7aPHR2
-> https://forum.tagdiv.com/topic/whatsapp-share/
Please provide some more details about this problem and some screenshots.
Please make sure that you do not have a plugin conflict, please deactivate all non theme plugins, also if you are using child theme or cache plugin, please deactivate them, clear all cache and try again.
is not a child theme
https://prnt.sc/ne54n7
https://prnt.sc/ne55ax
https://prnt.sc/ne55pn
and please check the views on the articles
https://prnt.sc/nf6ea2 – this is what i have in article
https://prnt.sc/nf6flx – this is what i have in analitycs
If you want to can set manually the number of views were to start to count, you need to go in post and go down to custom fields -> https://www.screencast.com/t/QrLJhZTtqAR
The view count will count each page view regardless of IP. If it changes after you refresh the page for example, that would mean it is working properly.
This count can be modified for each post in the post edit screen custom fields (if needed)
– http://prntscr.com/m9ytya
The functionality of the post view count cannot be changed by a theme setting. It can only be enabled/disabled.
Caching plugins can affect this option from working properly, you can try to activate this option
– https://www.screencast.com/t/kE41ZmJjyLK9
