Hello
I have updated my Newsmag site from 3.3 to 4.5 and got a small attached problem – one element appeared in the above and I do not see it in the editor and dont know how to delete it.
here is the link to page https://myukvisa.ru/tipi-viz-v-velikobritaniyu/turisticheskaya-viza-v-velikobritaniyu/
and here is the screen. https://ibb.co/hFLYQU
I will pareaciate your advice.
It seems to be a column text wrap as you can see here -> https://www.screencast.com/t/GKX3d5ZLwv Did you have checked it with TD Composer? Try to edit the page with TD Composer and check the results. Provide me a screenshot with your front end editor from TD Composer with your page elements.
but it is a post not a page.
I do not use TD Composer. It is visual composer for this post.
https://ibb.co/mr1FqU
On all other posts (exept one more) from this template I do not have it.
For example here is the same template https://myukvisa.ru/tipi-viz-v-velikobritaniyu/biznes-viza-v-velikobritaniyu/
but no such block.
Maybe, you did not see it because it’s an empty ROW. You can send us an email at contact@tagdiv.com with your log-in information (wp-admin) so we can further investigate it closer to your setup page.
