When I place a block with 6 news and define the order of the latest news, the second page of the block is shown first. It is only possible to view the first page with the most recent news after clicking on the pagination option. Through TagDiv, I’ve tried deleting and creating a new block with the same definition but the error remains.
Every help is welcome.
Hello @Jonasbrazil !
In order to avoid misunderstandings, please provide more information(screenshots/video) about what exactly you need to achieve or what is the issue there and your website link.
Ok. Here the screenshot. My site is https://www.teoriadigital.com.br/.
What I had mentioned happens as soon as you enter the site.
Hello @jonasbrazil !
Maybe it takes some more time, or it could be a cache problem. Please make sure you disable all the cache and delete the cache from your browser as well.
Hello Bettina, thanks for answering. I cleared the cache but it didn’t work.
Please make sure you have no other caching tools in your server.
Make a test and deactivate ALL plugins except tagDiv ones, also if you are using a cache plugin, deactivate it, clear all cache and try again.
If the problem is still there, then contact us via email at contact@tagdiv.com and provide the following:
– admin url and credentials
We will take a look and try to help you asap.
Hello Bettina! Thanks for getting back to me via email! You said that the unique article feature was already enabled on the homepage. So there was no need to do anything? I would like to know if you made any changes. Even to share here in the community in case anyone needs it in the future.
Yes, that was the only problem on your end.
That feature does not allow any post to repeat on the page.
