A problem with the header 8
There is no space between the menu items and the search icon. Even if there is only one item in the menu, it gets aligned right resulting in no space.
See this: http://postimg.org/image/yamj8k5f3/
A Live site is http://www.gdgtarena.com
Can you please inspect the menus to move it in middle? I mean to align it centre.
Like this:
LOGO <-space-> MENU <-space-> SEARCH
You can use position to move the menu and search as you like: http://screencast.com/t/DirLEMZ4Bqm
Hope this helps!
