A problem with WP Job Manager: td_ad_background_click_link
I have a problem. I installed the WP Job Manager plugin and I cant see the ads in Internet Explorer and Firefox (you can check this out: http://dojczland.info/praca-w-niemczech/). There is an error: Uncaught ReferenceError: td_block is not defined
site.js?ver=4.5d:1224 Uncaught ReferenceError: td_ad_background_click_link is not defined
site.js?ver=4.5d:814 Uncaught ReferenceError: tds_more_articles_on_post_pages_distance_from_top is not defined
If anybody know how to fix it, I would be glad for an answer!
Best regards,
Adam
The problem is, that I can see the ads only if Iam registrate… How can I fix it?
Please also test this using the theme’s ads system and make sure you have just the VC plugin active, let me know of what you find.
We haven’t tested the theme using WP Job Manager plugin so the plugin could not work well with the theme and from your above statement the plugin is in conflict with theme’s js.
You could also try to find and use another plugin, try to find a solution online or also address this to plugins authors.
Sorry for the inconvenience!
