a small problem
Hello sanket3811,
Here is talking about an image link from your header section which is a break and that’s why you bring this symbol. If you want to remove it, you should check your Theme panel, Header Ad section and delete from there the image which causes this error or tries to load another image. Clear all the caches, purge all CDN files and check the results.
Thanks for your understiading!
yah i did . thanks
