Hi!
I am trying to use the accordion element from visual composer in a page, and it works. But, in the moment that I open the same page with tagdiv composer, the accordion is distroyed and only appears the full text that was inside the accordion. I mean, it is impossible to combine the accordion from visual composer and then use tagdiv composer in order to add an element or do whatever and I need to use it.
So the problem is that in tagdiv I don´t have the accordion element and I can not use it from visual composer and then go back tagdiv because the accordion will be break.
So, do you know some plugin, some html code that I can put in a column text in tagdiv composer o some solution for that? I only want a sample accordion like in the following screenshot.
https://screenshot.net/es/5l1n2td
Pd: I also would like to congratulate for the last update!! With the accordion element just would have been perfect, haha.
Thank you in advance 😉
It is highly not recommended to edit pages built with one composer, with the other. The results would not be good. Visual composer specific elements such as the accordion will not be interpreted by the tagDiv composer.
You should decide on using only one builder for the website, to avoid any issues. We will add more elements for the tagDiv composer in future updates. An element similar to the Visual composer accordion is not available at the moment in the tagDiv composer, sorry for the inconvenience.
