Activation problem
If we have to activate 10 websites, why do you make us create 10 users for forum.tagdiv.com – why isn’t there an option to use an existing username for this?
I have to basically create x users for each website I activate – please fix!
For that you can use the manually activation
– https://www.screencast.com/t/y9OSLcsc
– https://www.screencast.com/t/AEKaTQM0
The registration data used on the first theme activation, is to be used for that key only. For the others try the manual activation method.
Can you include this button in that pop-up, because right now it is invisible to be honest down there.
I will tell your suggestion to our theme developers, and they will now what to do.
Thank you for message!
