I am using the ‘Ad box’ element on the homepage:
http://prntscr.com/q1jxtj
In ‘Use adspot from’ I choose custom_ad_1:
http://prntscr.com/q1jx1k
In Theme Panels -> Ads I put the html code of the advertising image:
http://prntscr.com/q1jwyh
But the homepage does not show:
http://prntscr.com/q1jy4x
The item inspector shows me that there is a css style (.td-a-rec-id-custom_ad_1) that hides it:
http://prntscr.com/q1jyra
When in ‘Use adspot from’ I choose ‘Header ad’ or ‘Sidebar ad’ it works fine, but I use those adspots in another section of my website.
How can I solve the problem?
Best regards
Joseph
I did everything he suggested. It is not solved.
According to the item inspector Element, the CSS that has display: none !important is in the main.css file.
You could check it. The style that applies is .td-a-rec-id-custom_ad_1
Is there any other way to solve it?
Best regards
Joseph
Hello !
– admin url and credentials
– cPanel url and credentials
Our team will take a look !
The problem was solved. I am using Kaspersky antivirus and it blocks the advertising in that case (Use adspot from :). But when ‘Custom ad’ settings in ‘ad box’ the antivirus does not block it.
With ‘Use adspot from: Header’ and ‘Use adspot from: Sidebar’ the antivirus does not block it because in css styles no advertising keywords are used.
You could evaluate and optimize the ‘Ad box’.
Best regards.
Joseph
