Good morning, I have a problem with an AD BOX module on my website, I have a banner in which they ask me to put a tracking number, but when I put the url in the “add url” field, the code overflows and appears in the front view and I can’t put it on the web.
I would also have the possibility to add this same track with a print pixel code, but I don’t know how to add it with this system. Thanks for your help.
Hi soportesoci,
I just made some test and for the when I set a link with tracking parameters I do not have the problem that you have.
Maybe your code has some special characters. Can you contact us in private via email to check the link tracking? If yes, then please contact us via email at contact@tagdiv.com
The code for the pixel it is usually used for images -> https://i.imgur.com/B65Fk53.png
