Can you provide us a link to see the issue? Do you mean you make changes in Theme Panel and the changes are not reflected in the front-end?
Do you have plugins installed, can you try to disable all plugins and see if works. If not work can you give us access to your WP to take a look, send via email at contact@tagdiv.com
