AD on top of Article Post
How can I add 728×90 AD to show in ARTICLE POST only, like this one: http://screencast.com/t/Wio7rZHCvXK
I’ve put my 728×90 code in the Header ad in theme panel but it’s also showing in the homepage, category pages.. how can I only show it on the article post?
Edit your single.php file(this is for the default post style) if you want for other post style add the code in all template styles, those files: http://screencast.com/t/YVfbJsUI
Code: http://pastebin.com/xgLhqvD8
Then use the Custom Ad 1 for you ad. Go to Theme panel -> Ads and paste your ad code in Custom Ad 1
Then go to Theme Panel -> Custom CSS and paste this CSS
.my-custom-ad div {
    margin-bottom: 0;
    margin-top: 32px;
Result: http://screencast.com/t/bG8QOJLjfXw
  • This reply was modified 11 years by Marius.
