Ad problem in header
Dear Sirs,
Last week I bought your theme NewsMag.
Everything was perfect but I have one small request.
At the top of the header with the logo is a script for the ad.
I would like that in this ad is replaced with a picture in .jpg format. I’m entered the path for the picture but I have a problem. Adblock blocks that picture because it is recognized as an ad.
Please tell me how I can change it?
Another problem I have with the smaller menu on the left side. It does not appear on my website http://www.mraclin.hr.
How can I activate that please?
Thank you in advance for your reply!
It seems that the adblock filters detect the ad container based on their classes so you could try to change those classes to avoid this.
Please check this tread fro more info on this: https://forum.tagdiv.com/topic/header-ad-not-showing/
Thank you very much for help ! I’ve fixed it !
Can you help me with second problem: smaller menu on the left side. It does not appear on my website !
Thanks again in advance !
Please provide more details as I’m not sure what you mean. Which smaller menu?
Do you refer to the mobile menu? – http://screencast.com/t/SsptninOjVR
I think for left menu marked with a red arrow on image – http://mraclin.hr/wp-content/uploads/2015/05/menu.jpg
Thanks a lot !
This is custom menu for our demo and it is not an option in theme panel to activate it. You can make this change – http://screencast.com/t/vxHFkftLpnE to appear and you can change link and text from – http://screencast.com/t/UxUrR54cH
Thanks a lot !
