Ad Problems
I’ve recently implemented some new ads for my website, ScreenGeek.net, and the ads load correctly on desktop, but not on mobile. The ad company says that other sites aren’t having this issue at all, so I think it’s something to do with the theme or the coding. It only does it with certain ads, so I’m not sure what to do. I also can’t attach an image on here, so if you happen to look, it might take a couple of clicks on the site to see what’s happening. It happens with ‘Pandora’ ads.
Hello screengeek,
I have inspected your website and I saw that your Ads does not work properly. So, please notice that our theme has been designed to use only the Google AdSense system and if you are using anther Ad provider, you can encounter any problem with these ads, sorry! Notice that our theme was not tested to be used with Pandora Ads and we cannot say for sure if it will work or not, sorry! As a quick solution, you can try using the AdRotate plugin because many of our users use it and it seems to work as expected with the theme.
