Ad slot location on mobile post
Hi!
In mobile web, the ad slot on the post pages is on the bottom on top of the footer. Is there a way to raise it higher? Would in-feed article be necessary here?
At that location, viewability is really bad.
Thanks,
Roberto
As I can see the ads on mobile appear like on desktop -> https://i.imgur.com/qy4GXeM.png -> https://i.imgur.com/SAeSQhr.png if you want you can check the mobile version of your homepage by editing it with tagDiv Composer -> https://i.imgur.com/LcP3Wne.png
Custom ad spots -> https://forum.tagdiv.com/custom-ad-spots/
