Add ACF Text on Flex Block X and Flex Loop
How add informations on the Flex Block X and Flex Loop like that (image)?
My Flex Block X
My Flex Loop
I want to add this date (is an ACF text) with the logo >> image
Thank you
Hello @vivreausmic !
Every new demo with CPTs has a plugin with the style of flex blocks, so you need to have it installed in order to have the custom style of flex blocks with CPTs and custom fields included. https://forum.tagdiv.com/edit-modules-flex-block-x/
This is the code: https://prnt.sc/GNFFs9BIkC24 from tds_doctors_pro_module1.php file.
I am completely satisfied with the current presentation of my blocks.
I have already tried with the proposed procedure.
By downloading the other models, I had bugs and conflicts.
I would simply like the piece of code to add, to display an information (text ACF field) on my Flex Bock X and the Flex Loop.
Is it possible ?
Thanks ?
The easiest method is the one in which you can edit those files with the style you need.
For customization and other services you can contact our custom work team here: https://tagdiv.com/premium-customization-services/
