Add additional tags and schema tags in post header
Hi Team,
1. I want to add additional Meta tags for Posts Head section such as meta, og and schema tags as per my requirement.for that i want to add a column in post admin page where I fill title and content.
2. I want to create a table to for each post from the admin page of content. For that, I have created HTML code for it is it possible to create a column for this and paste it in every post
Requesting you guys to please help me either with code or a plugin
Can any one hlep me in this
Hello ahmedyakub,
1)If you want to add more meta tags into our theme you should try using such a plugin with this functionality, like Seo Yoast plugin.
2)If you want to affect the post template by adding a table you should use a text with title element where you created your table and then, using the do_shortcode method you should add it in the post template you want. As a reference, you can check the following topic from here -> https://forum.tagdiv.com/topic/add-content-globally-to-bottom-of-each-post/
Hi I want to add more tags than what Yost plugin provide is there any chance to make a block in post admin panel so that I can add them directly to that post
hi i have tried them on newspaper but none of this works
Then search and try more online solutions, only through code or plugins you can do what you want. The theme does not have such a feature unfortunately.
