Please can you add the ‘category__not_in’ field for each component because I don’t want to overwrite your stuff each time.
Regards,
ex:
class td_slide extends td_block {
function __construct() {
$this->block_id = 'td_slide';
add_shortcode('td_slide', array($this, 'render'));
function render($atts){
$this->block_uid = td_global::td_generate_unique_id(); //update unique id on each render
extract(shortcode_atts(
array(
'limit' => 5,
'sort' => '',
'category_id' => '',
'category_ids' => '',
'category__not_in' => '',
function get_map () {
//get the generic filter array
$generic_filter_array = td_generic_filter_array::get_array();
//add custom filter fields to generic filter array
array_push ($generic_filter_array,
+array(
+ "param_name" => "category__not_in",
+ "type" => "textfield",
+ "value" => '',
+ "heading" => "Exclude posts from categories id (, separated)",
+ "description" => "",
+ "holder" => "div",
+ "class" => ""
In td_data_source
class td_data_source {
static $fake_loop_offset = 0; //used by the found row hook in templates to fix pagination. The blocks do not use this since we use custom pagination there.
* converts a pagebuilde array to a wordpress query args array
* creates the $args array from shortcodes - used by the pagebuilde + widgets + by the metabox_to_args
* @param string $atts : the shortcode string
* @param string $paged : page number /1 or /2
* @return array
static function shortcode_to_args($atts = '', $paged = '') {
array(
+ 'category__not_in' => '',
if (!empty($category__not_in)) {
$wp_query_args['category__not_in'] = explode(',', $category__not_in);
