Add Author Box to top of post
Hey guys,
I was wondering if there was a way to add the author box to the top of the post under the feature image, so that there is an author box at the top and bottom of the post. As we will have a lot of guest bloggers on our site it would be great to ensure that readers know straight away who has posted the blog.
Cheers
Adam
You can edit post template and copy author box code and paste it where you need to appear – http://screencast.com/t/Yjn83rHq8
Result: http://screencast.com/t/17LWjZbbJkap
Awesome thanks for that works like a charm
