how do I add code between these two? Is there any place I can add it? The header place in the theme panel already contains my adsense header code. I need to add another header code for functionality purpose. Where can I add it?
Yes, you can set the code in the theme panel > analytics/js code – https://i.imgur.com/G5prfuD.png
that holder already has code. How do I add another script to it?
Hi I cannot start a new ticket so I will communicate here. Suddenly Tagdiv is down and the whole website is looking weird. No themes are working
https://elitechronicle.com/
Hi elitechronicle, I just cheeked the website and this looks ok now – https://i.imgur.com/bySz6Rd.png
Now the problem that I see is that your website is infected – https://sitecheck.sucuri.net/results/https/elitechronicle.com
So I’m suggesting to make a full backup and update the theme to 5.4.3 make sure that you remove all no WordPress files, check the plugin using FTP and remove all plugins directories that are on your WordPress install and are not displaying on WordPress dashboard plugins.
