Add code between and
Hi:
Is there a way to ad custom code between <head> and </head> tags in Theme Panel? I would like to use Google DoubleClick code, but I need to insert the code between those tags, without touching the php files.
Oscar
hi,
sorry, you need to modify the php files.
Thanks for you message.
Radu A.
Hi:
ok, I found this plugin to add script code to the header and footer http://wordpress.org/plugins/header-and-footer-scripts/ so the php files stay untouchable 🙂
hi,
thank you for writhing your solution here, will help other users.
Radu A.
