Add custom code inside section
Can I add JavaScript in the <head> section from the “Theme Panel” or shaould I edit header.php.
If I add the code in the <head> section of header.php, does it affect when I update theme via “Evanto Market Plugin”
Regards,
If it needs to be placed in the head, insert in the header theme file, between the head tags
– https://www.screencast.com/t/VrkBzpze9
Any modification made directly to the theme files will probably be lost when the theme is updated.
You can make modification through a child theme, as this will not be affected by the theme update
– https://forum.tagdiv.com/the-child-theme-support-tutorial/
