I have the Magazine Pro template installed and I’d like to add a drop shadow between the white main panel of the site and the grey background pattern to define the break better. What’s the simplest way to do that?
This topic was modified 5 years by
sparky263.
sorry, been away on holiday last week. Here it is https://onlineinvestmentconference.com/
Light drop shadow just to separate front panel from BG
like this inv-communications.com/files/support/210726_OIC_Front_page_drop_shadow.jpg
This reply was modified 5 years by
sparky263. Reason: added mockup file link
I just checked your website and seems you have set already a shadow, but is not apply => https://www.screencast.com/t/vIXokEUclwb, please try to edit with tagDiv Composer the homepage, and after the header, you need to have a CSS Code =>https://www.screencast.com/t/CvkujL8gLtW2, open it => https://www.screencast.com/t/sRHhHBuDFand and check the code => https://www.screencast.com/t/4weukZyxDj
Are you using any plugin to remove the unused CSS or something similar?
Hi there, can’t believe its been exactly two years to the day that I asked what is now the same question (I haven’t been doing much with this site for the past two years. Been working on other stuff). I applied your fix at the time and the vertical shadow appeared. But now its disappeared. I checked your css input code, and its all there, but the shadow doesn’t appear. How do I get it back again?
site is: onlineinvestmentconference.com
Please check if you have this option enabled in Theme Panel -> Background -> https://i.imgur.com/iGdT286.png -> https://i.imgur.com/G7MdaQN.png
