Hello Topadmin,
If you want to add an HTML into a page when you are using the Mobile Theme, you should add the code in the Mobile Editor from here -> https://www.screencast.com/t/yoeUUVseqSVV
Hello Topadmin,
Notice that if you want to customize the archive pages, you need to do it via Cloud Templates. Check the following link here -> https://affiliate.tagdiv.com/#/load/Date and customize the Archive Template (Dates) using the Cloud Template. You can try to create using the above link (demo preview).
