Add flex module in a post
Hi, how can i add the flex module within a post ?
And have a way to customise like you do using tagdiv composer.
Also what would you recommend for adding tables in post ?
And how about for adding maps ?
Would be lovely if future updates includes maps and table.
– Flex blocks are available only with the tagDiv composer. Through this composer and cloud library plugin, post templates can be created from scratch or predefined templates can be imported (these can be modified as well).
– Without the tagDiv composer and cloud library plugin, only the default predefined post templates can be used.
– Standard HTML tables should display properly in the post or page content. I believe there are also plugins which can be used to create tables, maybe test a few plugins as well.
– Maps can be embedded, here is a guide (there are more online)
– https://www.wpbeginner.com/wp-tutorials/how-to-add-google-maps-in-wordpress/
– For the moment there are no table or map elements provided by the theme. Who knows, maybe at some point there will be.
