Add Lines between posts of [tagDiv] Block 4
I have add the block 4 on my sidebar to show the popular post of 7 last days
(http://www.alexiptoto.com/sacco-%CE%BA%CE%B1%CE%B9-vanzetti-%CE%B7-%CE%BC%CE%BF%CF%85%CF%83%CE%B9%CE%BA%CE%AE-%CF%85%CF%80%CE%BF%CE%BA%CE%BB%CE%AF%CE%BD%CE%B5%CF%84%CE%B1%CE%B9-%CF%83%CF%84%CE%B7%CE%BD-%CE%B5%CE%BB%CE%B5/)
I would like to add between the posts a horizontal line to separate them instead of to be blank white. Can you tell me from which file I add the code….
Try this CSS in the Custom CSS section of your theme panel:
.widget .td_mod_6 {
  border-bottom: 1px solid #7d7d7d;
Change the hex code to whatever colour you want.
To adjust the spacing, you can add
` margin-bottom: 10px !important;
After the border-bottom line, adjusting the px as required.
Thanks @TheMediumUTM!
Using .widget class will not work because the block dose not have a parent container with that class, best will be to use the css like this:
.td-post-sidebar .td_mod6 {
Result: http://screencast.com/t/oxKbz3Sd8ca1
This will work only for post page template, you need other css for other sidebars.
(Thanks for the clarification 🙂 I’ve done enough now with my site that I can’t always play around and replicate to make 100% sure…)
