Add small image/icon to top header
Is there a way to insert an image/icon to the far right of the top header bar, as shown circled in the example below:
Top Bar Icon
I have seen a previous topic about adding a social network to appear in backend of your profile and add a background image using custom css in Theme Panel. However, after every update the changes will need to be updated again.
Also, this is not a social icon but a regular icon with a link to a page for example.
Thank you
This will be easy to achieve with the new header builder fro Newspaper v9.5 -> https://tagdiv.com/whats-new-in-newspaper-theme-9-5-update/
I am not using the header builder. Is there a way without please.
I think that you can set in top menu an image and add to it a class, for custom css, for example I chose an image from media -> https://www.screencast.com/t/fPPFS8d8v2, go to menu, chose the top menu and ad a custom link -> https://www.screencast.com/t/NXA1qA1M5 now set some custom code for that image -> https://www.screencast.com/t/hQiZokdJWt
Hope this will help you!
Thank you, but in the media library I cannot find where to add a class. There does not seem to be an option?
Hi, from media you just take the url for the image that you want to set in top bar, the class you set in the menu, and the code for that class will be set in custom css
-> https://www.screencast.com/t/f8IraNUz6XsS
