Adding Audio block to Magazine_Pro Theme
Hello
How to add a podcast block to the Magazine_pro theme, just below the Video block.
Like to have a block as in: https://cloud.tagdiv.com/block-85-podcasts/
https://demo.tagdiv.com/newspaper_podcasts/
Thank you
You can add a podcast by following these steps:
1. Edit a page with TagDiv Composer, and access this: https://www.screencast.com/t/EKlM8MXND
2. Search right there about “podcast” and choose which podcast you want and select “Import section”
3. Edit a post and do these settings like here: https://www.screencast.com/t/JA2yJmdYBc
Post Format => Audio
Paste your audio link in the empty label called “Featured Audio”
Notice: You can add an audio link from SoundCloud or an audio link from your WordPress media files.
Hope that helps you!
  • This reply was modified 5 years by Bettina.
But, I like to add a podcast block to the Magazine_pro theme,
https://demo.tagdiv.com/newspaper_magazine_pro/
This block as in: https://cloud.tagdiv.com/block-85-podcasts/
Please see that the instructions you have given do not do it.
HELP
You need to first install the demo in your website and after that you can edit the homepage how I was explained you just above. It should be working.
Are you suggesting that we can not add podcast block to Magazine_Pro Theme?
We need to have the Magazine_Pro theme have the main layout and add a block for Podcast.
(Just like the Video Block)
Please advice
If you follow my instructions from the first reply, then you will find out that you can add a podcast or more. Also, I said that you can install Magazine_Pro Theme in your website and change it how you want.
Bettina
I am new to the theme.
I have installed the magazine_pro,
Sorry, Finding so much difficult to add the podcast block to the magazine_pro theme.
Hence, requested the instructions!
>I was unsuccessful to get the results following your first reply.
Still, I am struggling!
HELP!
Please follow this video: https://www.screencast.com/t/du45RCfJK
Bettina
Thank you so much!
Now, I got it!!
I just notice that the block is added to the end of the screen.
How can I move the block to above? We want it after the Video Block (Newspaper_Pro)
-Greenbooks
You can move any element in the page with TagDiv Composer using drag & drop, like in the following video: https://www.screencast.com/t/ZKqTEpFdPb
Thank you so much!
Thank you so much!
You saved my day!
