I want to start adding audio files of the posts to each article.
Is there anything built in or any recommendations anyone has how to do this?
Hi Chris Baird,
That depend on what exactly do you want to achieve. If you want to add the same audio file, then you can set the audio file in a single post template from tagDiv Cloud Library.
If you want to set featured audio, you can do it like this -> https://i.imgur.com/0PWMwoV.png -> https://i.imgur.com/Q93DXEs.png
Or if you want to add the audio format inside the article you can use the elements form Gutenberg editor -> https://i.imgur.com/5t5Lugs.png
Hope this will help you!
