adding more element to blocks
hi
I was wondering if there is a way to add more element to a block.
for example I am using block4. It shows, the title of the post, date, meta,..
however is there a way to add more custom field to the post in addition to the above?
Unfortunately, no, using block 4, you can’t display other fields. To achieve this you need to create your own module or import one and change the custom fields, you can find more details here: https://forum.tagdiv.com/modules-builder-newspaper-theme/ and assign the module using flex builder block -> https://forum.tagdiv.com/flex-block-builder-flex-loop-builder/
