Hi — I am working with an ad network to add a widget to my site, wherein I have “Other Articles You May Like” thumbnails underneath my posts — but I have no idea where to add the widget code within the Newspaper theme. My site is MotherHumor.com. Any help you could offer would be greatly appreciated. Thank you!
If you want to replace Similar Articles from post template replace it with you code: http://screencast.com/t/6iMZJ3sLBDlK or if you don’t want to remove Similar Articles just paste your in post template file where you want to appear.
Please provide more detail if this is not what you need.
Hope this helps!
I’d like to place it right below Similar Articles, but can’t figure out where to insert the code (not sure where the post template file is?). Thank you SO MUCH for your help and quick response!
When you edit the post you can set a template for your post: http://screencast.com/t/LJ3SQep7M6q so if you want to appear on all post templates(styles) you have to add the code in all files after Similar Articles: http://screencast.com/t/rjuZVrDx
