Hi Tagdiv Team,
I’m using the newspaper theme Review function for product reviews and sheema.
I added stars and a review desciption, but the google search console gives me an error:
“offer” and “review” is missing.
Attached a screenshot:
Do you know how I can add these two options?
Thank you in advance,
Dennis
Could you please tell me how to move that review area and how to customize the colors?
Hello @digitalbrothers!
Only if you will use a cloud template, then edit the post with TagDiv Composer and you can drag & drop the review elements and change the colors also.
