adding read more to posts in categories.
I”s like to add “read more” to posts in categories instead of the “…” 3 dots that appear now, can I safely add following to the functions.php without breaking the theme or is there a other solution?
// Changing excerpt more
function new_excerpt_more($more) {
global $post;
return ‘… ID) . ‘”>’ . ‘Read More »’ . ‘‘;
add_filter(‘excerpt_more’, ‘new_excerpt_more’);
The Read More Button can be set on flex block 1 -> Read More Button and this will be display on each post in part, this button is not available on blocks/flex blocks –
-. https://i.imgur.com/G7xHrWb.png -> https://i.imgur.com/dKv7prm.png -> https://forum.tagdiv.com/flex-block-settings-guide/
also using a pro demo or cloud templates you can edit the whole with tagDiv Composer.
I needed to have that button in a postloop but now I see that option to add a button is there as well! Thx for the tip!
Hi, I’m glad that I was able to help you!
If you have other questions, let us know!
Have a nice day!
