Adding review schema to my posts?
Something like I have on my Jekyll blog:
view-source:https://takanodan.net/2019/02/shield-hero/
<script type="application/ld+json">
  "@context": "http://schema.org/",
  "@type": "Review",
  "itemReviewed": {
    "@type": "Thing",
    "name": "The Rising Of The Shield Hero Ep. 1 - 5 review"
  "author": {
    "@type": "Person",
    "name": "Giacomo"
  "datePublished": "2019-02-11",
  "reviewRating": {
    "@type": "Rating",
    "ratingValue": "4.5",
    "bestRating": "5"
</script>
How can I do this in order to increase SEO, but avoid having the table at the bottom of the post?
More info on the schema: https://schema.org/Review
If you should use the theme review system the necessary review meta will be added automatically.
But you could use a different review system and add the meta with a plugin, for example
– https://kinsta.com/blog/schema-markup-wordpress/
Manually it would also possible by using the custom fields for example
– https://www.hostinger.com/tutorials/wordpress-schema-markup/
That Jekyll SEO seems to be a plugin from what I can find online, haven’t header of it up to this moment
– https://github.com/jekyll/jekyll-seo-tag
Thanks. I’m using the theme one as I want to avoid plugins, but is there a way to hide the box?
What box are you referring to exactly? maybe it is possible by some means. Let me know.
The review summary box with all the stars.
So the box that appears at the bottom of the post that has a review
– http://prntscr.com/mtf3w1
I could give you a code for it if you want to remove it – http://prntscr.com/mtf4eu
.single .td-review {
display: none;
It will apply to all posts that have a review. If I misunderstand, please post a link to the page where you want to do this, and some more exact details.
As a note, when using cloud post templates, you can choose which review element appears in the post page. The review section is broken into 3 parts, use the ones you want
– http://prntscr.com/mtf5ln
Let me know.
That’s awesome, thanks.
