adding side towers on left and right
Hi there,
I want to add advertisement side towers on both the side of main content div. so it should go under td-main-content-wrap class and around td-container.
Left tower will be before td-container and Right will be after container.
Website URL is http://aksharwebsolutions.com/ffm/ – can you please give me CSS code, so it all stays inline with each other (towers and main content)?
Your earliest response is greatly appreciated.
Thanks,
Arpita
You simply need to change the div positioning to absolute and then adjust the left/top proprieties: http://screencast.com/t/P9BPt9Tluk
#div-gpt-ad-tower-left{
position:absolute;
left:280px;
top: 295px;
If you want this to be a floating ad you can set the position to fixed so it will scroll with the content.
You can read more about css positioning here: http://www.w3schools.com/css/css_positioning.asp
how did you decide left: 280px;? How this can work as different screen will have different resolution?
It was just an example for you to see how the positioning works. I added the left propriety to highlight horizontal positioning. It was not meant as a permanent solution. In order to make it responsive it will need further customization.
