adjust box related article
Hello. How can I adjust the boxes that show the related articles so that they look correct.
On the links page (links page) at the end that option appears.
Screenshot
  • This topic was modified 3 years by ludyma.
  • This topic was modified 3 years by ludyma. Reason: added image capture
Hello @ludyma!
If you use a default template, then this is not customizable with the TagDiv Composer.
A cloud workaround could be to use the flex block builder with a custom module which can be build as you like and also by using the ajax categories dropdown: https://prnt.sc/-kk2lu4rkftq
Documentation here:
https://forum.tagdiv.com/flex-block-builder-flex-loop-builder/
https://forum.tagdiv.com/modules-builder-newspaper-theme/
