ads header problem
Hello when i update to NesPaper 8.7 i face this problem with google ads on the header it going up not in center between Main menu and top header
https://wwww.arabdebate.net
Also one more question i use AMP for posts only but when i use the mobile and open any posts its not redirect to AMP version its open as normal website i need to incluse /amp to the url so i can see AMP version
I cannot access your website at the moment
– https://www.screencast.com/t/glbE8zJ7J4v
AMP pages will be indexed and served by Google, you can view them if you want by adding /amp in the URL as you mention. The theme AMP plugin does not redirect anything. AMP pages will be served by Google from their cache.
hello sorry i add 4 wwww. you can access my website : https://www.arabdebate.net
Somehow I missed that, should have seen the URL was wrong. Indeed there is an issue with the header ad when using global block header template 17
– https://www.screencast.com/t/hKIlno4waF
I will add this on our list and it will be fixed as soon as possible. As a quick fix please enter this code in Theme panel->Custom CSS
– https://www.screencast.com/t/6pi8fUBMRvu
.td-header-rec-wrap .td_block_template_17 {
transform: none;
-webkit-transform: none;
-moz-transform: none;
-ms-transform: none;
-o-transform: none;
Sorry for the inconvenience.
Fixed
