Ads not responsive with Adrotate Pro
I have a problem with the size of the adverts on http://www.irisor.no. I would like the main ad (As for noe Sport1 and the orange-colored in the newsflow) to be responsive, but now they jump form full size to mini if I make my desktopwindow smaller. This also makes the ads very small on tablets.
The ads in the widget works like it should.
I am using Adrotate Pro for my ads.
Anyone that got an easy fix for a non-programmer?
Please try to use this method of implementation: https://forum.tagdiv.com/using-other-ads-non-adsense-ads/
Add your adroate code between the div tags.
Thank You for fast response!
I have tried this, but must do something wrong. The changes dosent effect the size on the ads as they shows.
At least they show correct on mobiles and computers, but I would like to see them be correct on tablets to.
Could You give me an exampel of configuration that should work?
Best regards
Tore
Please contact us via email at contact@tagdiv.com and provide a link to your site and wp-admin so we can login and investigate this issue. Please also post a link to this topic.
