Ads not working, "Newspaper" ads not going away
I used your Newsmag theme for quite some time and recently purchased the Newspaper theme for a new site. I am familiar with how the ads worked on Newsmag and expected them to work similarly. Here is my dilemma:
I pasted my Google Adsense code into each of the Theme Panel > Ads fields, but when I go to any page, it still shows the temporary “Discovery Newspaper” ads. So I tried hitting every “disable ad” switch to see if that would get those to go away. They still have not gone away.
How do I get rid of these temporary ads? If I delete them with TagDiv Composer, will that prevent my GoogleAdsense ads from showing up correctly?
Here is my website: whnynews.com
Usually, the ads in prebuilt websites are set in the element AD BOX, and you can remove it, edit with tagDiv Composer, select the viewport for phone and select the Ad box element and with right-click you can delete it => https://www.screencast.com/t/2GfCVx9BCAw7 or with drag & drop place it into the deleting red zone from the bottom right of the page
The ad box has 3 sections for ads: using theme panel ads -> https://i.imgur.com/KFa9ibl.png, using images/banners -> https://i.imgur.com/MfAPTaE.png and custom code -> https://i.imgur.com/2rh8SuD.png save it and will appear on the post (you can set a shortcode like a shortcode from adrotate plugin or other plugins).
