Ads Placements on left & right side empty place
Congratulations to tagdiv team for awesome and user friendly theme. I don’t know how to create website. With the help of support documentation i created
http://WWW.beansfry.com
1. Need your help to place side bar ads on left and right empty places. Also i want to increase left and right side place for 2 side bar ads with 160X600 dimensions, Right side 2 side bars and left side 2 side bars. (these ads done in photoshop its not Google Adsense).
2. My website is loading very slow please help. May be i missed some tweaking things in support document.
3.Can it possible to animate featured image (multiple images with fade or dissolve effect).
Thanks you.
Junaid
1. To place your ads in the sidebar you will need first to create a new sidebar in which you can add your sidebar ad or add the sidebar add into an existing sidebar, like this: http://screencast.com/t/nM5tELrP
Here is how you create a new sidebar: http://screencast.com/t/eATlwEHGE0C
Here you will have to ad the code for the sidebar ad: http://screencast.com/t/MO7gdQiOv
After this edit the page you want to have the sidebar ad on to and set the sidebar like this: http://screencast.com/t/hQGcO8BIf
If you want another sidebar on the left besides the one on the right, you can add it like this: http://screencast.com/t/woCxVdjX
This could help: https://forum.tagdiv.com/ads/
2. Check this topic and guide:
* https://forum.tagdiv.com/pagespeed-guide/
* https://forum.tagdiv.com/topic/pagespeed/
Also search the forum for tips and suggestions regarding speed there are many topics covering different issues and difficulties you may encounter.
3. Then only featured image effect we have is using post style: https://forum.tagdiv.com/topic/newspaper-v-4-0-topic/
You could try to use a plugin for this.
Hope this helps!
