Ads will not show in article top, inline and bottom article
I’ve placed ads in Theme panel, and the will not show. I’ve not disabled on any devices. What’s wrong?
https://spurt.no/
When pasting ads code direct into posts, it works perfectly, but not when adding it ads in Theme Panel.
https://spurt.no/
If you use a cloud/PRO template, then you should add the ads when you edit the post with TagDiv Composer in the element called ” Single Post Content ” in the tab ADS.
For a default template you should add the ads in theme panel.
I think you misunderstand. I’m talking about top article, inline article and bottom article in Theme Panel under Ads. Nothing display when I place ads there.
https://spurt.no/
I checked your website and it seems you use a cloud/PRO template, which means if you add the ads in theme panel they will not reflect in your website, only if you will add that element: https://www.screencast.com/t/QfALKvl4Phcx
