Adsense ads problem
When I use theme ad section, adsense ads are not showing or they are appearig so late except header ad. That’s why, now I use an ad plugin. But I don’t want to use a plugin? Why I have this problem?
reelyorum.net
Please make sure that the plugins you have do not make this problem, please deactivate all non theme plugins an clear all cache, see if the problem is still there.
Let me know the results!
Hi Calin,
I deactivated all plugin except tagdiv composer and speed booster. I celaned all cached before deactivate wp super cache. Result ise better now. But still there is a problem. Ads are still apperaing late. I am about to die because of these problems :)). My adsense revenue decreased dramatically.
Please try toy fix to error that you have in console -> https://www.screencast.com/t/9bXK85q3FyAr , this will help you to make you site faster, and the ads will be load faster too.
Also please check this topic were you can fine some topic for theme optimization
-> https://forum.tagdiv.com/topic/hello-11/
