My website is https://www.thechinesezodiac.org.
I’ve implemented AdSense code for auto ads in the “Analytics/Javascript Codes” section of the Theme Panel. Currently, there are displayed only anchor and vignette ads, along with a banner positioned just below the article footer (please see the attached screenshot).
The problem I’m encountering is the absence of automatic ads within the articles themselves. The four ads currently visible in the articles have been manually placed using the “Ad Inserter” plugin.
If I deactivate the “Ad Inserter” plugin, the four manually inserted ads disappear, but auto ads do not replace them.
On the Google AdSense website, I can see the designated areas for automatic ads placement, but they are not being displayed.
What might be the issue?
Thank you for your response! However, I believe there’s more to the issue. As I mentioned in my previous message, when I remove the manually inserted ads, no additional automatic ads appear, except for a single one located under the footer, which is completely outside the website’s content.
Furthermore, when I switch the WordPress theme, auto ads promptly populate the entire site, including within the articles.
So, it seems that there’s definitely another factor at play here. It could be related to a different JavaScript error or some other issue preventing the automatic ads from displaying within the article content.
I’m hopeful for more assistance to address this matter, rather than a response like “automatic ads appear where they please.”
I have the same problem. When AutoAds in Adsense are activated, I have to put at least one add code within the post article to show any ads whatsoever. If I don’t do so, there are no ads. When I put one, automatic ads including vignettes, anchors and in-page ads all appear.
I linked my website through Site Kit and Ads.txt plugin. Now I try to put the script in the Analytics/Js Codes setting in the Theme panel, but it doesn’t save. I click Save and exit. Then I return and it’s blank. Do you have any idea why this is happening? Do I miss something?
Update:
It’s all fixed now. The thing is that I updated WordPress to 6.4, which caused problems with the mobile theme. Advised from other posts in the Forum I deactivated and deleted the Mobile Theme, then purged the cache and reinstalled it. Now it works fine, and shows adds everywhere on Mobile and Desktop with no need to add blocks with adds in posts. If someone faces problems with the Adsense AutoAds, that might be the solution, especially if the problem were ads for mobile, which was mine.
